Question Advice for Tag
qwer81
Hello Filip, what settings you advise for the section tag?
In "Tagging Setting" what is the optimal setting? Thread or Title Only?
In the "Manage Content Tagging", instead, what do you advise?
P.S. I have excluded tags from indexing
In that case, you can probably get away with making it title-only. If you find that doesn't work for you, you can always switch it back and clean/rebuild the tags DB later down the line :)
