Advanced Post Thanks / Like v3.0.4 Alpha 5 (vB5) Released!
Fillip H.
Staff member
Owner
Developer
Hey all,
We're committed to keeping our modifications up to date with the rapid advancements in modification author tools for vBulletin 5 Connect, and to that end we're releasing Advanced Post Thanks / Like v3.0.4 Alpha 5, available immediately for users running vBulletin 5.0.4 or higher.
This release focuses on compatibility with the new tools available to us in vB 5.0.4, which will let us easily generate new pages populated with modules on installation rather than requiring user action post-install.
Additionally, as the CSS of vBulletin is being improved upon, we're making any necessary changes to our products to stay up to date.
Lastly, any other bugs noticed during testing have been fixed.
If you like the product you can show your support by nominating it for Mod of the Month here: Advanced Post Thanks / Like v3 (vB5) - vBulletin.org Forum, and also please rate it if you have the product installed.
Change: 5.0.4 is now the minimum required version
Change: Changed module wrapper to use the built-in template
Fix: Fixed UserCP issues related to CSS changes
Fix: Fixed various other CSS change issues
Fix: Fixed issues with clicking buttons in the post
Fix: Fixed issues with saving button as Active in the AdminCP (may require you to re-set the Active status depending on your setup)
As always, thank you for your continued support!
Discuss this news here.
