Hey all,
After a highly successful Beta period, we're announcing the availability of the Gold version of @Advanced Post Thanks / Like v3.0.0.
New to the Gold version is one small feature:
Advanced Post Thanks / Like v3.0.0 (Gold):
Feature: (Pro) Added ability for emails to be turned off by default, can be turned back on by users via their UserCP
Below is a complete collated list of features new to v3.
Buttons / Hide
Integration
(vB4) Forum Block
General / Other
Thanks for your continued support
Discuss this news here.
Buttons / Hide
- Each button can be set as "Default" for Attachments and Content. When posting via Quick Reply, the default button(s) will be set as Required
- Notifications can be disabled on a per-button basis
- The "thanks bar" in posts displays the number of users who has clicked each button for all areas.
- These clicks can be disabled via a vBulletin Option
- (vB4) You can choose what portions of the postbit should be coloured via the colour thresholds.
- (Pro) Email notifications (can be disabled globally) on a per-button basis
- Email notifications go through an extra (hopefully) invisible redirect to clear its notifications, to ensure users are logged in before viewing their profiles
- Button text can be disabled via vBulletin Options
- (Pro) You can disable notifications on a per-button basis
- (Pro) You can set a flood limit (in seconds) that serves as a delay between button clicks
- (Pro) Individual users can be excluded from using the mod
- (Pro) Individual buttons can be excluded from individual Integration options
- (Pro) "Given" and "Received" stats can be turned off for individual buttons
Integration
- (vB4) [DBTech] DragonByte Gallery: Images
- Social Groups
- User Notes
- Visitor Messages
- (Pro) Blog Entries
- (Pro) Blog Comments
- Integration can be disabled via vBulletin Options
(vB4) Forum Block
- Tabbed interface to choose between "Recent" and "Top" button clicks
- Ability to select from any of the available buttons and display the 5 recent clicks from that button
- "Top" tab on the forum block, lists top clicks for the selected button
- Control the timespan in which the "Top" period is calculated for
- Block has less superfluous text and also displays the button icon
- Ability to deny usergroups access to the forum block
General / Other
- The importer from Abe's Post Thank You Hack should now correctly import Received User ID (future imports only)
- (Pro) vB Option: Set number of seconds between each button click
