Hey all,
Three bugfix updates for you this weekend, mainly for APTL issues reported by you guys but also a couple spurred on by the availability of vB 4.1.8 Beta. We're not going to ask you to hold off on upgrading to Beta versions of vBulletin - after all, while we try to stay up to date with beta versions ourselves, it's impossible for us to do as thorough a job testing as your forums can provide
In short, if you ever feel like upgrading to beta vBulletins, don't worry. We'll support it and release compatibility hotfixes (and full updates) A.S.A.P.
Disclaimer: Support is provided for the latest version of our products only. We cannot guarantee vBulletin compatibility with old versions of our mods.
The APTL update has another purpose though; it prepares your product for the upcoming vBActivity & Awards update.
With all that pesky stuff out of the way, on to what you came here for: Changelogs!
Advanced Post Thanks / Like v2.0.2:
Fix: (Pro) SQL error on "List" page
Fix: (Pro) In certain cases, it was possible that the Post Colour Threshold setting reverted upon reaching 10 clicks of a button, or did not work at all
Fix: (Pro) The "Clicks Per Day" limit was not working in some cases
Fix: (Pro) The "First Post Only" option was not working correctly
Fix: (Pro) Only active buttons now appear in the UserCP for the user to configure postbit display for
Fix: Potential fix for custom profile styles looking odd
Fix: Potential fix for a reset() error on some PHP versions when performing Maintenance actions that had nothing to do.
Fix: Inactive buttons still showed up on the Hottest Threads / Posts page
Fix: Hidden buttons still showed clickers on the Statistics page
Change: Changed instances of "N/A" to the "Hidden Content" phrase to eliminate confusion
Change: Includes compatibility for future versions of vBActivity & Awards
Note: Edit / save any custom buttons (i.e. buttons beyond Thanks / Like / Dislike) to ensure vBAA compatibility is properly applied.
InfoPanels v2.0.3:
Fix: Added compatibility with vBulletin 4.1.8
vB Optimise (Pro) Hotfix:
Thanks to Gage for their wakeup call re. vBulletin 4.1.8 and vB Optimise compatibility
As always, thank you everyone for your support
Discuss this news here.
InfoPanels v2.0.3:
