Not planned Add BBCode to embed donation drive widget in threads.
Rick7C2
I'm in need of a donation addon and after looking at the features for DBTech Donate it's almost perfect for what I need.
I only require a BBCode to embed specific donation drives in threads.
Something like...
[donate]{DonationDriveID}[/donate]
On second thought maybe you could make a new addon that allows you to embed widgets in threads. This way it would work for any widget and not just DBTech Donate.
If there is already a way to do this please let me know so I can purchase this addon.
Thanks,
Rick
In XF2, you are able to deploy a widget that you can optionally set to only include specific donation drives. As per the description in the Widget system in XF2:
Widgets with no position will not appear anywhere, but you can call the configured widget instance directly in templates using the <xf:widget key="widget_key" /> syntax.
In other words, if you create a donation drive widget with a widget key widget_key, you can then modify any template you want and insert <xf:widget key="widget_key" />.
You can limit this template edit to specific threads by wrapping the template in an <xf:if> block.
Hello @Rick7C2,
We hope your ticket regarding DragonByte Donate has been addressed to your satisfaction. This ticket has now been closed.
DragonByte Donate
