joroom
Hello
Since i installed this mod on my forum, it has become very slow, it is also crashing sometimes and causing very high mysql usage & CPU usage.
I cannot see anything suspicious in mysqld.log file nor in the apache error log file.
Any ideas why this is happening ?
If i disable the mod, everything goes back to normal.
Thanks
Jo
Are you using a datastore cacher other than Filecache in your vB config.php? If not, you may want to investigate whether you can install and/or use XCache or APC. They will help reduce some of the computational requirements of DBSEO.
Hey,
I am using VBOptimize PRO (filecache) .
So if i switch to Xcache in vboptimze, the problem will be solved ?
Thanks
Jo
I have removed DBSEO.
You should mention in the plugin specs that it is very CPU & RAM extensive.
I have tried installing XCache and i have also bought vbOptimize in hopes that the problem will be solved, however it wasnt.
My forum is on a managed server and my database size is more than 5gb.
Its a shame. Is there any way i can get a refund ?
You will need to change the Datastore config parameter in vBulletin's config.php file (/includes/config.php) in order for DBSEO to pick up on it.
That's very subjective, for instance this forum and hundreds of other forums run it just fine.
We also provide a free Lite version for people to try out, which we recommend doing in order to determine whether a mod is right for their particular forum.
Due to the nature of digital software, we cannot offer a refund on products that have been downloaded. We could offer you the equivalent amount in store credits that can be applied to future purchases instead, if that's acceptable to you :)
Already tried that, but still the forum was very slow
I understand and accept :)
