The sitemap generation did work automatically this morning. I could see the XML files in the correct directory.
I wanted to manually get it to build the sitemap. So in DBSEOCP ? Sitemap Settings I clicked on Build Sitemap. Mainly to see how long it took. In the VBSEO sitemap generation I know it was around 26 seconds to do all sitemaps.
Anyway, it generated about 4 sitemaps, and just sites there saying... Processing.......
Although there is nothing running as looking at the processor activity its dormant.
So I clicked on Build Sitemap again, look at the processor activity, its 100%, and its what to be expected. After 60 seconds it says its time out.
I've deleted the sitemap files in the store_sitemap directory. the directory is chmod 777 (the auto creation worked fine this morning)
So I go in to scheduled tasks and manually kick of the scheduled task. I get this message...
So I restart the httpd process, clear DBSEO cache, VBOptimise Cache and Maintenance/Clear system cache. But it still does the same. Cant think of anything else to try at the moment.
What makes the schedules task think its still running?
Thanks
Dan.
The sitemap is currently being generated in the admin control panel. The scheduled task will not run while the sitemap is being built in the control panel.
Thanks
Dan.
