Bulbagarden
Just purchased the product today to move away from vBSEO. It seemed to install correctly, and the vBSEO setting import also appeared to work like a charm. The URL Rewrite Settings were copied over exactly as we had them.
However for some reason it seems the URL's aren't actually rewriting. Instead, we're just seeing the standard vBulletin URL's for threads/forums/etc. Can't seem to identify any obvious reason why this would be happening. Double-checked to be sure, and the mod is properly enabled, the .htaccess has been setup according to the readme instructions.
Any ideas as to what might be going on here, and what we might do to resolve it?
Are you behind some form of cache service like CloudFlare? If so, that may be a reason. Try flushing any cache systems you may be running.
Can do, will just be a couple of mins. I'm currently in the middle of importing vBSEO likes to your other mod however, so you should probably hold off a little bit before doing anything drastic. Forums are currently switched off.
EDIT: And sent.
EDIT2: Just finished everything for the vBSEO likes, and am now reopening the forums to our users.
Our forums aren't behind any caching system, no.
You have Zend OPCache enabled on your forum, and it is caching PHP scripts, which is rarely a good idea.
It is highly likely this is behind your problem, and in either case it's making debug efforts impossible as it does not correctly refresh files when they are edited on the server.
Please modify php.ini and set opcache.enable = Off then restart Apache. I recommend installing XCache and upgrading to PHP 5.4 / Apache 2.4 as a means of increasing performance, rather than relying on PHP file caching.
Requested changes and updates have been made. Let me know if there's any more issues with debugging.
Update: Your PHP Info page is now showing as using XCache instead of Zend Cache, but it is not configured correctly.
Add this to your php.ini file to enable XCache to work as intended:
xcache.var_size = 512M
xcache.var_ttl = 7200
xcache.admin.enable_auth = "off"
Update 2: The reason why forum rewrites are not working is that your Forum Cache is corrupt. vBulletin bypasses this by re-querying all forums, reducing the performance of the forum as a whole as a result.
I believe this is due to the é character. I'm going to test whether replacing it with the HTML Entity é will still display correctly in the front-end and if so, replace it in the database for all forum titles & descriptions.
Update 3: After an hour of finding invalid characters in your forum descriptions, I have successfully replaced all instances of é with é, an instance of a MS Word-style dash - with a "normal" dash, and I have found 3 forum descriptions that need to be converted to Unicode HTML entities.
forum416: 日本語で話してもいいですよ。
forum492: 日本語で話してもいいですよ。
forum236: 日本語で話してもいいですよ。
I have removed these characters from the listed forums' descriptions for the time being.
Sorry for not replying earlier. Things been a bit crazy this past week IRL.
It's looking like the changes you made fixed the problems, and the addon is now working correctly. Thank you very much for all your assistance. =) Will be installing the update later this week, looking forward to seeing the new features you've added in action. =)
