You have a little Bug into the Setting Meta Description Length.
When the Setting is 160 then is the Description 161 Characters long.
The Problem is the subStr Function, you make String Length + 1.
Change this Code Line:
to this:
$_description = self::subStr($_description, self::$config['dbtech_dbseo_metadescription_length']);
to this:
$_description = self::subStr($_description, self::$config['dbtech_dbseo_metadescription_length'] - 1);
