Question Installed DBSEO over VBSEO - Have a loop on Forum and CMS while using vBadvanced indx
ctrenks
I disabled VBSEO, installed the DBSEO and ran the VBSEO import, flawless on all that but I now have a rediect issue with the forums and CMS parts that are named differently. May have an issue from using VBadvanced as well?.
So appears the menue buttons are changed so the forum homepage works ok, but threads report a loop, as well as CMS
Also width of the template is broken sice the install but i should be able to resolve this
Slot machine resource and slot machine reviews
Thanks!
Chris
Have you turned off the vBulletin "Friendly URL" Canonical URL enforcement in the vBulletin Options?
I had a chunk of code from Vbet Translator in htaccess, as i have that turned off for now I removed that and it appears to function correctly now. Only issue is that it added menue items that Tabs vbSoporte is supposed to remove.
here is the code that caused the redirect loop
# vBET
#RewriteRule ^/?(af|sq|ar|be|bg|ca|zh-CN|hr|cs|da|nl|en|et|tl|fi|fr|gl|de|el|iw|hi|hu|is|id|ga|it|ja|ko|lv|lt|mk|ms|mt|no|fa|pl|pt|ro|ru|sr|sk|sl|es|sw|sv|zh-TW|th|tr|uk|vi|cy|yi)/$ vbenterprisetranslator_seo.php?vbet_lang=$1&redirected=/ [L,QSA]
#RewriteRule ^/?(af|sq|ar|be|bg|ca|zh-CN|hr|cs|da|nl|en|et|tl|fi|fr|gl|de|el|iw|hi|hu|is|id|ga|it|ja|ko|lv|lt|mk|ms|mt|no|fa|pl|pt|ro|ru|sr|sk|sl|es|sw|sv|zh-TW|th|tr|uk|vi|cy|yi)/(.*)?$ vbenterprisetranslator_seo.php?vbet_lang=$1&redirected=/$2 [L,QSA]
#RewriteCond %{REQUEST_URI} !(admincp/|media-library/|modcp/|dbseo_sitemap/|cron)
#RewriteRule ^((archive/)?(.*\.php(/.*)?))$ vbenterprisetranslator_seo.php [L,QSA]
#RewriteCond %{REQUEST_FILENAME} !-f
#RewriteCond %{REQUEST_FILENAME} !-d
#RewriteCond %{REQUEST_FILENAME} !^(admincp|modcp|clientscript|cpstyles|images)/
#RewriteRule $ vbenterprisetranslator_seo.php [L,QSA]
DBSEO does not add any menu items, I'm not sure whether that's what you were referring to?
Somehow its causing Tabs vbSoporte to no longer remove the tabs, and I had to re-add an older forum tab. I can keep searching on that issue. I want to make sure this all works correctly before I replace VBSEO on my main site shortly.
Do I need to purchase a branding free add on for each product i buy as I was looking at the tabs sytem you have as well in place of the older free one. I will de brand everything once i am sure I want to keep it, but I dont want to pay $400 in branding fee's
The easiest solution might just be for you to upgrade to vB 4.2.x, that way you don't need a mod to edit the tabs :)
As for the Branding Free, we do have a Global Branding Free modification that will work for all current and future products and automatically remove all their branding :)
Slightly more expensive, but if you intend to use a lot of modifications it'll end up worth it by far.
OK, think I have resolved all my issues other than the VBET translator one, will p[lay and then upgrade my other VBSEO sites to DBSEO. Thanks again, and please don't leave us like they did!
Were you able to get Vbet working with vbseo? I am currently delaying purchase either until I can ensure I can use both together safely. I want to keep my old url structure but i'm told without the vbet and dbseo being compatible i'll never be able to integrate.
