Question How do I define a separate shoutbox background?
CrackingZilla
So after changing to another style (from vBstyles) called Aria Carbon, My shoutbox seems to have a problem. This is how it looks with the problem:
As you can see, the 'Black' portion is the problem. You can't read the text over there! However, I was able to fix the black portion by editing "blocksubhead_background" and by doing so I did fix the shoutbox, however it brought me another issue and it was, rest of my forum, was changed too as blocksubhead is being used in a lot of different places in my forum!
This is how it looks if I fix my Shoutbox:
But then the new problem is,
So my question is, How do I only change the blocksubhead_background for Shoutbox only? Or can I put something in the CSS for the shoutbox so it doesn't uses blocksubhead and instead uses something like "albumlist_blockbody_background"? because that would be perfect too!
Waiting for a response,
Thanks in advance!
Hi there,
Your site is actually listed on our piracy tracker as having an illegal version of Advanced Post Thanks / Like, vBNavTabs and vBShout - we checked manually and there are indeed unlicensed Pro files for these products on your server.
For obvious reasons we are unable to support people using illegal versions of our software, please purchase licenses for these products to use them legally.
Regards,
Hi there,
Regards,
How can that be? Please do a re-check. and I did buy the licenses for another domain but I don't use that anymore so since long back, I started using them on this mentioned domain. I wouldn't know this would cause a problem because I thought being the same owner, it would be okay!
If so, please edit the URL of the licenses in your Client Area so that it's pointing to your new site :)
Let me know when this is done and I'll re-scan.
Technically, this is the new site where I am using my DragonByte products and that's why I included the genuine link. If I didn't have a legal copy of the products, I wouldn't have dared to open a ticket in here mate.
Okay :)
Could you please log in to the account that purchased the products and make the requested URL change, then let me know?
Thanks!
Hello CrackingZilla,
