racersimage
Hey there, I received the following email from my webhost this morning.
Wondering what I can do about this, I never had this trouble with vBSEO so maybe there's a tweak I can do to remedy this problem?
It has come to our attention that your hybrid server is consistently using more than the allotted 1 CPU core. Your hybrid comes with 1 Guaranteed CPU core. When you push over a load average of 1 (it's consistently running between 2-3) that means that your sites are using beyond the 1 Guaranteed CPU core that comes with your plan. While we allow you to burst beyond the 1 Guaranteed CPU, if you are using 2-3 times the CPU time on the hardware node, this is a sign that you need to either buy more Guaranteed CPU cores on your Hybrid Plan or upgrade to a Dedicated server.
A dedicated server may be more cost effective in the long run. Each additional core adds $25/month to your invoice. Based on your Grove graphs, you need to add at least one additional core to your hybrid plan.
This CPU usage is clearly being caused by the CPU intensive dbseo script:
/usr/local/lsws/fcgi-bin/lsphp5:home/nascartr/public_html/community/dbseo.php
Please let me know how you'd like to proceed.
Kind regards,
Nick Teeple
Managed Dedicated Servers | Managed VPS Web Hosting | WiredTree
Toll Free: +1 866-523-8733
Local: +1 312-447-0510
Fax: +1 312-447-0514
https://www.facebook.com/WiredTree
https://www.twitter.com/WiredTree
https://www.wiredtree.com/Google+
