vBNavTabs 1.2.0 for vB 4.2 Gold Released
Ozzy47
Former Developer
#vBNavTabs 1.2.0 (Gold)
After a successful beta period I am happy to announce the release of #vBNavTabs 1.2.0 (Gold) for vB 4.2
With this release the Lite version is now available and can be downloaded here, https://www.dragonbyte-tech.com/vbecommerce.php?do=demo&productid=120 The Pro version is available in your customer area if you have purchased a license.
Thanks once again for your continued support, and all who have been involved with #vBNavTabs . :)
You will find the version for for vB4.2 in the downloaded zip in a folder called vBNavTabs For vB 4.2 ONLY!!! That is what you use if you are running vB 4.2
If you like the product you can show your support by nominating it for mod of the month here, [DBTech] vBNavTabs - Navbar Tabs / Tab Management v1 (vB4) - vBulletin.org Forum and also please rate it to help cancel out the users who 1 star our mods.
Here is a complete feature list of what is included in this version.
Complete Feature List vB 4.2
Lite Features
  • Stylevars
    • Has a stylevar to set the min width of popup boxes.
    • Has a stylevar to set the padding around sublink items.
  • General Settings
    • Option to display the product version or not.
    • Option to remove the Hivelocity branding link in the footer. (Lite)
    • Option to enter a Branding Free key if you purchased one for the mod.
    • Ability to show a Search Tab, works similar to the Global Search Box.
    • Ability to set which usergroups can see the Search Tab.
    • Ability to set the text color of the Search Tab.
    • Option to have Drop Tabs open on hovering over them.
    • Option to have Sublink Menus open on hovering over them.
  • Add / Edit Tabs
    • Ability to set the text color of the tab text.
    • Ability to set which usergroups "Can" see the tab.
    • Ability to set which usergroups "Can Not" see the tab.
    • Ability to choose which styles the tab shows on.
    • Ability to set Tab Target, four options on how you want tabs to be opened in a web browser.
    • Ability to add a title to the tab, which users see when the hover over the tab.
    • Ability to choose which menu to act as the dropdown for the tab, (editing tab only).
  • Add / Edit Menus
    • Ability to move the menu to a different parent tab, (editing menu only).
    • Ability to set the text color of the menu text.
    • Ability to set which usergroups "Can" see the menu.
    • Ability to set which usergroups "Can Not" see the menu.
    • Ability to choose which styles the menu shows on.
    • Ability to add a title to the menu, which users see when the hover over the menu.
  • Add / Edit Links
    • Ability to move the link to a different parent tab, (editing link only).
    • Ability to set the text color of the link text.
    • Ability to set which usergroups "Can" see the link.
    • Ability to set which usergroups "Can Not" see the link.
    • Ability to choose which styles the link shows on.
    • Ability to add a title to the link, which users see when the hover over the link.
Additional Pro Features
  • Stylevars
    • Has a stylevar to add padding around the images.
    • Has a stylevar to set the images directory, so you can use different images for items on different styles.
  • General Settings
    • Ability to hide the Global Search Box.
    • Option to show a image on the Search Tab.
    • Ability to easily change the image for the Search Tab.
    • Select 1, 2, or 3 columns to show on usergroup selection area, when adding/editing items in the Navigation Manager useful for forums with alot of usergroups.
    • Ability to add unlimited extra navbars to add the tabs to.
  • Add / Edit Tabs
    • Ability to set which navbar the item shows in.
    • Ability to set a image to show on the tab.
    • Ability to add rel="nofollow" to the tabs.
    • Ability to have notes for the tab, viewable when you edit a tab.
  • Add / Edit Menus
    • Ability to set a image to show on the menu.
    • Ability to add rel="nofollow" to the menu.
    • Ability to have notes for the menu, viewable when you edit a menu.
  • Add / Edit Links
    • Ability to set a image to show on the link.
    • Ability to add rel="nofollow" to the link.
    • Ability to have notes for the link, viewable when you edit a link.
Discuss this news here.
