Hey all,
DragonByte Tech is proud to present yet another addition to our portfolio, thanks to our end of year bonanza of free modifications: Threads Auto Close, available immediately for vBulletin 4.x.x.
Threads Auto Close?
Threads Auto Close is a professional forum management mod, allowing administrators to automatically close threads after X post or X replies.
Threads Auto Close is the ideal product to eliminate the bumping of older threads.
Threads are not closed in the database, they appear as if they were closed. So, if you deactivate or uninstall the mod, threads appear as open again.
Note: Threads that are marked as closed by this mod via the Auto Close After X Replies setting, can not be reopened due to the fact that they have reached the max replies you set. Only way to re open them is to increase the reply limit or disable that feature.
Note: This was created on vB v4.2.0 but I imagine it will work on any 4.x series.
The mod is available here, Threads Auto Close DragonByte Tech - vBulletin Mods & Addons or here vBulletin.org.
If you like the product you can show your support by nominating it for mod of the month here, [DBTech] Threads Auto Close v1 (vB4) and also please rate it to help cancel out the users who 1 star our mods.
Major Features
Close After X Days: Administrators can set threads to auto close after a defined amount of days.
Close After X Replies: Administrators can set threads to auto close after a defined amount of replies.
Forum Settings: Administrators can set which forums threads to auto close after X days or X replies.
General Settings
Discuss this news here.
Threads Auto Close?
Major Features
General Settings
- Option to toggle plugin on or off.
- Option to remove the DBT branding, if you purchased a branding free key for the product.
- Option to remove the Hivelocity from footer.
- Option to hide the version number in the footer.
- Option to close thread after X days.
- Option to close sticky threads or not.
- Forum selector to choose which forums to auto close threads in.
- Setting to close threads after X replies if so desired, overrides the close thread after X days setting.
- Usergroup setting to select which usergoups will see the threads as closed.
- Forum selector to choose which forums the threads do not auto close on, if you choose All Forums in the other setting.
- Option to include sub forums if the parent forum is selected.
- Option to enter forum id's of threads you want excluded from auto closing if it is in a forum you have threads auto closing.
- Option to enter the id's of the users you want to see the threads as closed if they are in a forum you have threads auto closing. Useful if you only want certain users to see threads closed instead of usergroups.
- Option to add a "Closed" prefix on forumdisplay to the thread title if the thread is closed via this mod.
