DragonByte Forum Tabs v1.0.2 (Gold and Lite) Released
Former Developer
Hi everyone,
This week sees the awaited gold release of DragonByte Forum Tabs now v1.0.2. This release of #DFT sees a number of bug fixes and performance enhancements (thanks to Fillip H.). There are also additional features including the ability not to display the Category Tabs (for those who don't need to use the Category Tab features), integration with #vBShout in the display above the Category Tabs as well as the ability to now use vBulletin's notices system and add notices that will only appear above the forum list and control which tabs they will appear for.
The full list is below. Would like to get any feedback we can to continue to improve DFT.
Features
Feature: Subforums can be added or removed via a button on the Forum Home page.
Feature: When adding or editing a forum in the AdminCP you can now add the forum automatically to a users favourites list on their next visit to the site.
Feature: Standard vBulletin notices can now be assigned only to appear on a tab and will then appear only below the tabs.
Feature: Option to not display the Category Tabs.
Feature: Tab clicking flood check
Feature: vBShout integration with Category Tabs.
Feature: vBulletin notices can be displayed tabs and are loaded with the AJAX refresh.
Fixed: Wrong bburl variable in several templates.
Fixed: Issue with margin in Opera.
Fixed: Issue where reload image wouldn't move to the currently selected tab.
Fixed: An issue where on uninstall two fields would be missed from the user table.
Fixed: A slight delay on the unidle refreshing.
Fixed: Vertical alignment issue in some styles for subforums on the Forum Home.
Fixed: When Forum Tabs is disabled via it's Settings (Enable DragonByte Forum Tabs) it correctly disables the tabs display.
Improvement: Decreased loading time and resources of AJAX loading of tabs (Thanks to Fillip H.).
The updates also brings a Lite version of DFT with a full feature list below. We would suggest that when updating that you empty the forumtabs and forumtabs_pro folders as there have been several changes in file structure with this update.
If you like the product you can show your support by nominating it for mod of the month here, DragonByte Forum Tabs - vBulletin.org Forum and also please rate it to help cancel out the users who 1 star our mods.
Complete Feature List
Lite
AdminCP
  • Customizable Tabs and Category Tabs
  • Per Category Style
  • Usergroup controlled permissions for each Category and Tab
  • Option to sticky Tabs and Categories to prioritise them in display
  • Set default tab per Category to override global defaults
  • StyleVars for customizing the Tabs and Categories
  • Can choose between image, text or both image and text tab display
vBulletin Options
  • Set how many columns hidden/unstickied Category Tabs are displayed in
  • Set how many columns subforums are displayed in on the forum home
  • Enable or Disable the 'More' tab that contains hidden/unstickied Category Tabs
  • Tab Idle Timer setting
  • Global Default Tab setting
  • Option to display notifications to users or not
  • Set Default Usergroups when creating new Tabs and Category Tabs
  • Disable the display of the Category Tabs
Forum Home
  • Tabs load using AJAX
  • Category Tabs can use different styles
  • Tabs and Category Tabs can use an image only, text only or both text and images
  • Favourite Tab
  • Add forums to Favourites tab by one click on Forum Home and Forum Display pages
  • Add forums via User Control Panel
  • Drop down menu to add favourite forums in Forum Display pages
  • Unstickied/hidden Category Tabs toggled by 'More' button
  • Dimissable notifications for users who have not set a favourite forum or a default ta
  • Subforums organized into customizable columns.
Pro
AdminCP
  • Optional default or forced forums for Favourites tab
  • Choose which instance of vBShout to display for that tab, if any (requires vBShout)
vBulletin Notices
  • Set whether a notice will appear above the forums list for a particular tab
Forum Manager
  • Automatically add a forum to the Favourites list for all users
vBulletin Options
  • Tab Refresh Timer setting
  • Option to display Unread Threads Counters on Tabs
  • Tab Refresh flood check to prevent excessive tab reload
Forum Home
  • Tabs automatically refresh
  • Tabs automatically idle
  • Tabs automatically unidle
  • Remove all favourites options in drop down menu on Forum Home and Forum Display pages
  • Add and Remove all subforums from favourites list
  • Set default tab to load in the User Control Panel
  • Integration with vBulletin's default Notices system so that notices will appear above the forums only when set to
  • Unread Thread count can be placed within the Tabs
  • vBShout integration above forums per tab (requires vBShout)
Discuss this news here.
