Nirjonadda
cometchat online user's avatar does not show with vBCredits,If i Disable vBCredits cometchat online user's avatar are working,please any fix update about on this?
without vBCredits
with vBCredits
Please try individually disabling each vBCredits plugin until you find the culprit.
Advanced Post Thanks / Like v1.1.3
The Exclusive functionality should now function correctly in all cases.
Fixed Tapatalk view.
Fixed a conflict issue with the CometChat Picture (ccpic.php) file.
Fillip
A lot of plugin, I cannot find.
I'm extremely confused. You appear to have dug up a 3 year old post of mine.
Could you please disable each plugin found under the vBCredits product in the Plugin Manager until you find the one that breaks the avatars?
I can't see CometChat on your site using the account details you provided. Please provide instructions for how to activate the CometChat display so I can test this issue.
I am no longer able to connect to your FTP, once I try to browse to a folder I receive the following message:
[21:29:00] 227 Entering Passive Mode (37,221,170,231,230,41).
[21:29:00] Opening data connection to 37.221.170.231 Port: 58921
[21:29:00] MLSD
[21:29:21] A connection attempt failed because the connected party did not properly respond after a period of time or established connection failed because connected host has failed to respond.
Please let me know once you have corrected this problem.
This issue with ConfigServer Security & Firewall,OK I have disabled ConfigServer Security & Firewall,Please can you check now?
This should now be fixed on your site, it was a bug with CometChat that caused a conflict :)
If i upgrade new cometchat version Does get this issue again? If yes and how to ask cometchat Developer for fix this bug?
Yes, upgrading CometChat will most likely produce this issue again.
They can fix this conflict (and similar conflicts with other mods) by changing all instances of resolve_cp_image_url to resolve_ccpic_image_url in ccpic.php - that's what I did on your site and it works perfectly :)
Legacy vBCredits II Deluxe
