Not really specific pages per say, but their is some additional areas in the pro version you can toggle vBo on/off.
vB Optimise: Cache Dismissed Notices
This option specifies if you would like vB Optimise to cache Dismissed Notices.
When using the vBulletin notices on your forum, any that can be dismissed will generate a query by vBulletin to check the users notices that have been dismissed. The result of this is a query everyhere notices are displayed. vB Optimise can cache this data to stop the query from executing.
vB Optimise: Cache Showgroups Query
In showgroups.php vBulletin execute a query which can become more intensive as your user count increases. vB Optimise can cache this query for X hours so that the query is ran a minimal amount of times.
Note: This setting indicates hours, by default this is set to "4" for four hours, to disable simply enter 0.
vB Optimise: Forum Display Query Enhancement
Within forumdisplay.php, vBulletin executes a query to fetch the count of threads/new threads. vB Optimise can adjust this query to use a better alternative that will yeild the same results but faster.
Note: If this results in a MySQL error you may be using an old version of MySQL, you can disable the option or upgrade your MySQL installation to resolve the issue.
vB Optimise: Cache Forum Home WOL
If you display your WOL ("Who's Online") on your forum homepage, you may be aware that it can create additional load if you have a lot of users online. Large forums usually have this feature disabled to save the load completely. vB Optimise can cache this data for X minutes so you're able to display this data without adding load on your forum.
Simply enter the number of minutes you want to cache the Forum Home WOL for, by default this setting is set to 4.
Note: To disable this setting, enter 0. Additionally, this setting will be ignored if your Forum Home WOL is disabled.
vB Optimise: Guest Full Page Caching
This option if enabled will allow entire pages of content to be cached for Guests. This is recommended for forums who usually have a lot of Guests online, HTML output will be saved for X minutes which results in faster page loading (for guests only) and a dramatic reduction in queries executed.
How to enable: To enable this setting simply enter an integer to specify the cache lifespan of content in minutes, the higher the value the more "stale
vB Optimise: Overload vBCache Handler
vBulletin 4 has a new integrated cache system that is used through your forum extensively and in some cases extreme in regards to CMS, Permissions and Forum Blocks. Unfortunately vBulletin currently only has a Database controller for this cache which results in a mass of queries executed throughout your forum which is unrequired.
Turning this setting on will allow vB Optimiser to overload the vBCache Handler and use your desired Opcacher Operator configured in these settings. This can save you upto 10+ queries on some CMS pages, and several others where Permissions or Forum Blocks are used.
