Hi!
After updating DragonByte Tech: Advanced Post Thanks / Like (Pro) to the version 3.1.1. some posts disappear (blank post). If I disable the product the posts reappears.
How can I solve?
Best regards
Firstly, I can't access that page as I'm asked to login.
Secondly, that screenshot doesn't tell me much - I don't speak Italian, so I have no idea what the post says.
Can you check 2-3 posts that "disappeared" with the mod disabled and see if you can notice anything similar between them?
On the writing highlighted in pink (similiar thread) should see the text of the message, which I entered in the two image does not appear.
Can you please translate the writing in pink for me so I know what the contents of the post is replaced with?
The problem was that you appear to have re-purposed the "Dislikes" button, yet the "Post Collapse Threshold" setting was still attempting to collapse the post.
There was some other conflict preventing the collapsed post from working, but I didn't look into that since it appears as if you're not using this feature :)
