Bug Possible conflict with iTrader
It seems that I am having some trouble between with my iTrader plugin and the DBSeo Pro. The SEO seem to be in good working order. iTrader always seem to get an error and will not function correctly. The hosting company that I am using has suggested that if the there is a possible conflict if the xml file was imported from vBseo and used with DBSeo the same error can occur. Since I had you install the plugin can you verify if the xml file was imported or not. Also are there any known issues between these plugins?
Are you sure that the "www." part is not required for the Deal URL?
I know of at least one forum that uses this mod alongside iTrader without conflict.
Hello Fillip H.,
It looks like I have resolved the issue with iTrader. It was pointed at the wrong part of the forum. I have corrected the input and iTrader seems to be working now.
Since before I took over this forum iTrader had not worked correctly. I guess it has been incorrectly configured all the time.
If I find out about any alleged conflict between iTrader and Db SEO I will report it back here.
Thank you for your help.
