Nxt Customer Aug 1, 2014 #1 I was wondering if this is something I caused or a small bug you'll notice the Send Private Message text is over the edge, same with Silence/UnSilence.
Fillip H. Staff member Owner Developer Customer Aug 1, 2014 #2 This is most likely due to the custom font and/or custom styling on the pop-up. If you try it on a default (unmodified) skin, you'll see this doesn't occur
Nxt Customer Aug 1, 2014 #3 I figured it was something I did. I use Google Fonts. Thanks! Always so helpful.
