Bug New section created - rewrite rule not updated --- inaccessible by default.
Mental
Scenario
1 - created a new sub forum
2- added a moderator
3- went to homepage to click , URL incorrect (not rewritten)
Incorrect URL: forumdisplay.php?f=844
correct URL: /f844/
me scratches head.
Thanks.
FIX:
Enable then disable persistant SEO urls (must rewrite something). I don't have them enabled as i have 6m URLS and unsure on how it would effect performance.
The fix would be to clear the system cache - this happens when you save any DBSEO settings or when you click the dedicated menu item.
Alternatively, it would have sprung to life within 1 hour (the TTL of the cache). This only happens if you have Datastore caching enabled in config.php and it's set to something other than Filecache.
