Question Manual for SEO Pro ?
apleschu
Is there a manual available for SEO Pro? I have it currently installed but turned off since I am getting lots of 404 errors, apparently point to non existent or not caught URLs
At this moment I don't even know what to ask, so therefore the question for a manual
404 errors are most commonly a result of not editing the .htaccess file in the same directory as your forum is located, and/or running alternate webservers like Nginx and not applying the proper rewrite rules to its configuration.
Can you please confirm whether you have either uploaded the supplied .htaccess file from the /do_not_upload folder (if you didn't have a .htaccess file already), or that you edited your existing .htaccess file as per the readme.txt document?
Yes, I copied and edited the supplied file.
Maybe if that helps: When I click on the "forums" tab it directs me back to the "Whats new?" tab, (which is the default)
Thank you, we are slowly getting there. With a manual I would not have to bother, but alas.
Now I can select all the tabs in the navbar I see all the forums, but on many forums I get a 404. And on the forums I see I get 404 on threads. I believe I did clear the cache. Doing all those tests on a live forum is somewhat nerving.
Update: I have made some configuration changes on your forum and it appears to work as intended now :)
I should warn you that your Forum URL format settings may introduce problems if two forums resolve to the same SEO'd URL. You can fix this by customising the URL formats to also include the [forum_id] variable. This will also provide a slight boost to performance.
