Lite folder / Pro Folder
OpenVMS
When we are using a plug-in, its includes the lite folder, and the pro folder.
I have been uploading both, and it works fine.
Can we safely remove the lite version of the plug-in if we have paid for the pro version and using the pro version from the server?
No, the Lite folder is required for the operation of the mods. It contains all the core files.
Also, quite a few mods have different core files for Lite and Pro. Our downloads system allows us to dynamically strip out Pro-only code from the core files if you're downloading the Lite version (or we're downloading it for vB.org), so you should always re-upload all files when upgrading from Lite to Pro :)
