Hi,
I tried to activate the CDN Integration of vB Optimise. When I enter my Windows Azure details everything seems to work fine. The data syncs and the site works fine in Firefox and Opera. However one browser tells me, that not everything is as it should be: Internet Explorer is precise and does not load non-HTTPS data when visiting a HTTPS site. After I realised that the files that are stored in the CDN are not called in Internet Explorer I realised that HTTPS overall had gone with the CDN integration.
Is it not possible to utilize CDN when the vBulletin board is running via HTTPS?
If it is possible, how do I have to do it, where do I have to make changes?
Kind regards,
Cornelius
Kind regards,
Cornelius
