Captive Reefs
I've got an instance of the slider on my forum home which works perfectly along with the parallax javascript (a custom add-in) that I run. However on the CMS page, one or the other slider/parallax fails. I think the only time the parallax script works is when it is using a cached version...and then the slider won't load.
Either way, I think it works on the forum page because the slider scripts are loaded before the parallax script, whereas the CMS page they are loaded last.
I guess I'm hoping you can give me an idea of how to move my parallax script so it will load after the slider on the CMS. Or if you have another idea why its not working, I'm all ears.
(BTW- I'm still not live with vb4...so this is only a test site right now.)
