scalemotorcars
I installed the lite version from vb.org before purchasing the pro and Im glad I did because the only way I could get it to work was by commenting out "https://ajax.googleapis.com/ajax/libs/jquery/1/jquery.min.js" Problem is I used this ajax as part of my login so I kind of need it.
I tried the setting to enable and disable the jquery in the plugin but that made no difference. With the above mentioned ajax the slider never fully loads.
Is there a workaround?
