Question Advanced Usertagging for vB 5.2.1
Big-Pete
Hi,
Is advanced user tagging v 3.0.6a7 compatible with vB5.2.1?
I also tried Your Thanks & likes plugin but that kept coming up with a URL error so I disabled it..
Are you no longer developing plugins for vB5.2.1?
I've used for plugins since you started and would love to be able to continue to do so..
Regards
Pete
Hi Again,
I've just noticed that whenever I enable an addon we get an internal 500 error, currently as it's a brand new site I only have two addons installed and they are
advanced user tags and ajax threads.
Microsoft Edge comes up with an internal 500 error, firefox come up with a system error message and chrome seems to work ok.
Any idea what may be wrong? I'm new to vB5, but I've got 9 years or so experience with vB3 & vB4.
Regards
Pete
We released a hotfix yesterday to resolve AdminCP issues with our vB5 mods when running on vB 5.2.1.
At this time we are not developing new modifications or adding new features to our vB5 modifications due to how unstable vB5 is as a platform. If you are interested in running custom modifications, I would strongly recommend switching to vBulletin 4 or XenForo, as they are both very stable platforms that have thriving modification communities.
Could you please check your server's error log for the real error behind a 500 Internal Server Error?
Hi Fillip H.,
I've done the hotfix and sadly still have the issue. We go this error in the logs.
PHP Warning: current() expects parameter 1 to be array, null given in /var/www/insignia-owners.com/forum/core/packages/dbtechajaxthreads/api/ajaxthreads/refresh.php on line 36, referer: System Error
PHP Warning: array_slice() expects parameter 1 to be array, null given in /var/www/insignia-owners.com/forum/core/packages/dbtechajaxthreads/api/ajaxthreads/refresh.php on line 36, referer: System Error
Update: I've added a hotfix to the latest version of AJAX Threads for vB5 that should resolve this :)
Hi Fillip H.,
We're still getting this issue whenever we enable either advanced thanks or ajax threads plugin.
any help will be gratefully received as the site is due to open this week..
Error :API Error
Controller: site
Method: api_subdomain
Error(s):
array (
0 =>
array (
0 => '<div class="forum-off restore">Sorry, iMySITE.com Is Being Built from the ground up. We will be open soon...</div>',
1 =>
array (
0 => 'exception_trace',
1 => '## /var/www/mysite.com/forum/core/vb/api.php(482) Exception Thrown
#0 /var/www/mysite.com/forum/core/vb/api/wrapper.php(116): vB_Api->checkApiState(\'api_subdomain\')
#1 [internal function]: vB_Api_Wrapper->__call(\'api_subdomain\', Array)
#2 [internal function]: vB_Api_Wrapper->api_subdomain()
#3 /var/www/mysite.com/forum/includes/api/interface/collapsed.php(201): call_user_func_array(Array, Array)
#4 /var/www/mysite.com/forum/includes/vb5/template/runtime.php(506): Api_Interface_Collapsed->callApi(\'site\', \'api_subdomain\', Array, false, true)
#5 /var/www/mysite.com/forum/includes/vb5/template.php(324) : eval()\'d code(3): vB5_Template_Runtime::parseData(\'site\', \'api_subdomain\')
#6 /var/www/mysite.com/forum/includes/vb5/template.php(324): eval()
#7 /var/www/mysite.com/forum/includes/vb5/template/cache.php(134): vB5_Template->render(false)
#8 /var/www/mysite.com/forum/includes/vb5/template.php(346): vB5_Template_Cache->replacePlaceholders(\'\\r\\n\\t\\r\\n\\t\\r\\n\\t\\t<scri...\')
#9 /var/www/mysite.com/forum/includes/vb5/template/cache.php(134): vB5_Template->render(false)
#10 /var/www/mysite.com/forum/includes/vb5/template.php(346): vB5_Template_Cache->replacePlaceholders(\'<!-- ##template...\')
#11 /var/www/mysite.com/forum/includes/vb5/applicationabstract.php(479): vB5_Template->render()
#12 /var/www/mysite.com/forum/includes/vb5/frontend/routing.php(148): vB5_ApplicationAbstract::showMsgPage(\'\', \'<div class="for...\', \'bbclosedreason\')
#13 /var/www/mysite.com/forum/includes/vb5/frontend/application.php(21): vB5_Frontend_Routing->setRoutes()
#14 /var/www/mysite.com/forum/index.php(58): vB5_Frontend_Application::init(\'config.php\')
#15 {main}',
on line 510 in /var/www/mysite.com/forum/includes/vb5/template/runtime.php
Step 0: showErrorPage() called on line 215 in /var/www/mysite.com/forum/includes/vb5/applicationabstract.php
Step 1: handleException() called
Exception API Error
Controller: site
Error(s):
array (
0 =>
array (
0 => '<div class="forum-off restore">Sorry, MYSITE.com Is Being Built from the ground up. We will be open soon...</div>',
1 =>
array (
#11 /var/www/mysite.com/forum/includes/vb5/applicationabstract.php(402): vB5_Template->render()
#12 /var/www/mysite.com/forum/includes/vb5/applicationabstract.php(215): vB5_ApplicationAbstract::showErrorPage(Array, false)
#13 [internal function]: vB5_ApplicationAbstract::handleException(Object(vB5_Exception_Api))
#14 {main}',
That does not appear to be related to our mod, as no mention of any DBTech mod exists in the error message. Have you installed a "subdomain" addon, or any addon that deals with subdomains?
Hi Fillip H.,
Thanks for your reply.
The only addons we're using are
vBulletin 5.2.1
DragonByte Tech: Advanced User Tagging (Lite) 3.0.6a7
DragonByte Tech: AJAX Threads (Lite) 1.1.2a4
Forum Runner 5.2.1
OneAll Social Login 1.1.2 Social Login for vBulletin
VigLink
I have noticed that our version of cURL is 7.15.5 which was released in August 2007, is it possible that this could cause the error? I've asked vb support for help, but as always they are dragging their heels..
Thanks Fillip H.
Regards
Pete
Hi Belazar,
I've just upgraded the site to the latest release vB5.2.2 and we're still getting this issue. If enable one of your plugins such as usertagging I get this
error.
Error :API Error
Controller: usertag_core
Method: getCopyright
Error(s):
array (
0 =>
array (
0 => '<div class="forum-off restore">Sorry, mysite Is Being Built from the ground up. We will be open soon...</div>',
1 =>
array (
1 => '## /var/www/mysite/forum/core/vb/api.php(496) Exception Thrown
#0 /var/www/mysite/forum/core/vb/api/wrapper.php(116): vB_Api->checkApiState(\'getCopyright\')
#1 [internal function]: vB_Api_Wrapper->__call(\'getCopyright\', Array)
#2 [internal function]: vB_Api_Wrapper->getCopyright()
#3 /var/www/mysite/forum/includes/api/interface/collapsed.php(198): call_user_func_array(Array, Array)
#4 /var/www/mysite/forum/includes/vb5/template/runtime.php(506): Api_Interface_Collapsed->callApi(\'usertag_core\', \'getCopyright\', Array, false, true)
#5 /var/www/mysite/forum/includes/vb5/template.php(324) : eval()\'d code(1): vB5_Template_Runtime::parseData(\'usertag_core\', \'getCopyright\')
#6 /var/www/mysite/forum/includes/vb5/template.php(324): eval()
#7 /var/www/mysite/forum/includes/vb5/template/cache.php(134): vB5_Template->render(false)
#8 /var/www/mysite/forum/includes/vb5/template.php(346): vB5_Template_Cache->replacePlaceholders(\'</div>\\r\\n\\t<div c...\')
#9 /var/www/mysite/forum/includes/vb5/template/cache.php(134): vB5_Template->render(false)
#10 /var/www/mysite/forum/includes/vb5/template.php(346): vB5_Template_Cache->replacePlaceholders(\'\\r\\n\\t\\r\\n\\t\\r\\n\\t\\t<scri...\')
#11 /var/www/mysite/forum/includes/vb5/applicationabstract.php(487): vB5_Template->render()
#12 /var/www/mysite/forum/includes/vb5/frontend/routing.php(148): vB5_ApplicationAbstract::showMsgPage(\'\', \'<div class="for...\', \'bbclosedreason\')
#13 /var/www/mysite/forum/includes/vb5/frontend/application.php(21): vB5_Frontend_Routing->setRoutes()
#14 /var/www/mysite/forum/index.php(58): vB5_Frontend_Application::init(\'config.php\')
#15 {main}',
on line 510 in /var/www/mysite/forum/includes/vb5/template/runtime.php
Step 0: showErrorPage() called on line 219 in /var/www/mysite/forum/includes/vb5/applicationabstract.php
Exception API Error
Error(s):
array (
0 =>
array (
1 =>
array (
#11 /var/www/mysite/forum/includes/vb5/applicationabstract.php(406): vB5_Template->render()
#12 /var/www/mysite/forum/includes/vb5/applicationabstract.php(219): vB5_ApplicationAbstract::showErrorPage(Array, false)
#14 {main}',
Likewise If I disable usertagging and enable ajax thread I get this error.
Error :API Error
Controller: ajaxthreads_core
Error(s):
array (
0 =>
array (
1 =>
array (
#4 /var/www/mysite/forum/includes/vb5/template/runtime.php(506): Api_Interface_Collapsed->callApi(\'ajaxthreads_cor...\', \'getCopyright\', Array, false, true)
#5 /var/www/mysite/forum/includes/vb5/template.php(324) : eval()\'d code(1): vB5_Template_Runtime::parseData(\'ajaxthreads_cor...\', \'getCopyright\')
#15 {main}',
Exception API Error
Error(s):
array (
0 =>
array (
1 =>
array (
#14 {main}',
Hmm, I wonder if it could be caused by the forum being turned off. Can you try setting the board to online and see if that resolves it?
Hello Big-Pete,
Legacy Advanced User Tagging
