alan92rttt
In the documentation for the product is says its compatible with vbSEO. I would assume that means that is will support the same URL structures that vbSEO does.
In the pro-features list there is an entry for "vBSEO Importer". What specifically does this import?
Yes, it will support your current vBSEO structure.
The importer looks for your vBSEO configuration file named "config.xml" which contains all of your current vBSEO settings in it.
Yeah, but do bear in mind that the Lite version of DBSEO does not support custom URL structures - only a choice between the preset ones. You could configure the Pro version to match your exact vBSEO URL config manually.
I don't remember, to be honest, but I think they do. I cannot guarantee this, however. Feel free to test it :)
As this ticket has received no further replies, I'll close it. If you have any further questions or issues, please feel free to start a new support ticket. Thanks!
