Question vBNominate Pro No sidebar block
scalemotorcars
Bought the pro version just for the CMS and Sidebar block and nothing. I did the overwrite when upgrading I checked the settings and all I get is the forum home block just below the navbar just like on the Lite version.
What am I doing wrong?
Daniel
Have you checked to see if new blocks are available?
If they are not, can you try clicking the Rebuild Block Cache link? If that is not available without debug mode, can you try clicking the Clear System Cache link under the Maintenance ACP menu area?
I did everything you said and I still see the same Nomination Sidebar Block that came with the Lite version. I tried to enable it and got nothing.
I checked the settings and I see settings to display the forum home block and when I turn that on I get the one across the top. Turn it off and make sure the Forum sidebar block settings are turned on and still nothing.
I also dont see a CMS widget anywhere.
The issue was that the installer only generates the widget if you are installing the Pro version in the first place, it doesn't generate the widget if you are upgrading to Pro at a later date.
I've passed this on to the developer and I have manually ran the widget generation code @ your site so you should now have the widget available :)
The widget block now shows but there's nothing inside of it. I tried making nominations to see if they would be applied and nothing.
Still no forum side block either????
As per the feature list, both the CMS Widget and the Forum Sideblock only show results of the latest nominations that have ended. Since the rotating nominations by design have no end, they are not included in the list.
At the moment, the mod does not store previous winners for rotating nominations.
I understand this is not optimal for your needs but unfortunately it's not feasible to re-design the functionality of the mod on-the-fly like this.
Sorry I couldn't bring better news :(
EDIT: I've spoken with the developer and it seems that rotating nominations do show historical entries in the forum home and CMS blocks, but only past nominations - as far as I can tell there's no blocks for ongoing nominations.
So your saying there's no way to show the Current nominated threads in any side block... Just the winners of past nominated threads.
Couldn't the display in the CP of the current nominated threads be posted in a side block. That would make more sense so members know what threads are being nominated.
That is my current understanding of the situation, from talking with the developer, yes.
It's not exactly copy/pastable, there is no block to display the ongoing nominations because there weren't any demand for it, according to the developer.
So when you were looking at the settings do they look correct for a recurring monthly poll? Like I said Ive been messing with it for so long that Im just unsure.
And, will the forum sideblock finally show once a poll is started or just after a poll is finished? Same for the widget that sits empty right now.
It will only show the results once a poll has finished. I couldn't find anything incorrect about your settings, however we'll need to see how it works once a poll has ran its course to be sure.
Hello scalemotorcars,
Legacy vBNominate
