I have integrated vBAvatars with the "Quick Links" and "Community" Menu, but using vBNavTabs, it doesn't appear. Is this a bug?
Also, when selecting the body style you can pick one, move on to the next option and then there's a HUGE scroll bar and at the bottom you can pick another item. It's not loading in the correct frame or something else is messing up. Internet Explorer?
I cannot try to use it on the default skin as I have removed it from vBulletin.
Thanks
Thanks
