vB Optimise v2.6.1 Released
Fillip H.
Staff member
Owner
Developer
Hey all,
We're releasing vB Optimise v2.6.1 in order to add a new feature for Pro customers, and fix a reported bug for both Pro customers and Lite users. Pro customers will now be able to optionally cache plugin code, improving performance especially for forums with a large amount of modifications installed.
If you like the product you can show your support by nominating it for mod of the month here: vB Optimise v2 (vB4) - vBulletin.org Forum or here vB Optimise v2 (vB3) - vBulletin.org Forum, and also please rate it to help cancel out the users who 1 star our mods.
vB Optimise v2.6.1
New Features:
(Pro) Plugin Cache
  • Stores all plugins in a PHP file
  • Improves performance for plugin execution
  • Allows for plugin code to be cached by opcode cacher
Bug Fixes And Issue Fixes:
  • "Variable passed by reference" errors should now be resolved
  • (Pro) MS Azure CDN will now use the same URL Scheme as the forum, improving HTTPS support
As always, thank you for your continued support :)
Discuss this news here.
