After some more investigating I have found it to be a problem in my style. When using the default vbulletin style it works, when I use my customized style it fails.
This browser is AJAX compatible
vbulle...s?v=407 (line 11)
this.moves[k].costs is undefined
[Break on this error] if (parseInt(this.monster['stats2']...this.moves[k]['costs']['stamina']) ||
forumo...s?v=103 (line 208)
Firing System Init
Fire vB_XHTML_Ready
Fetch Cookie :: vbulletin_collapse (null)
Hmm I have no idea what could be causing that, you should try doing a comparison between the default and customised and see if you can spot the difference.
We don't supply area images unfortunately, only battleground images.
