GarethBurrows
Hiya
Have implemented this mod, and imported thousands of records, and its all working nicely
I see there's an expandable postbit element, which I can integrate manually into my tmeplate and it works nicely. However, I'd love to just display the total thanks or have the postbit element expanded without having to click it. Basically I want to display the total thanks for each user all the time in the postbit without having to expand anything
So something like this below
<dl class="userinfo_extra">
<vb:if condition="$post['joindate']"><dt>{vb:rawphrase join_date}</dt> <dd>{vb:raw post.joindate}</dd></vb:if>
<vb:if condition="$post['field2']"><dt>{vb:rawphrase location_perm}</dt> <dd>{vb:raw post.field2}</dd></vb:if>
<vb:if condition="$post['age']"><dt>{vb:rawphrase age}</dt> <dd>{vb:raw post.age}</dd></vb:if>
<dt>Thanks</dt> <dd>is there a variable I can put here?</dd>
{vb:raw template_hook.postbit_userinfo_right_after_posts}
Is this possible, or is it possible to set the postbit element you provide to just be expanded by default?
thanks
Gareth
thanks
Gareth
