Bug Unknown column problem
SametY
Hello @Fillip H.
I have updated DragonByte eCommerce 1.5.3 today.
My problem is as follows. Would you help me with this topic?
XF\Db\Exception: MySQL statement prepare error [1054]: Unknown column 'xf_dbtech_ecommerce_address.is_default' in 'order clause' src\XF\Db\AbstractStatement.php:228
Stack trace
SELECT `xf_dbtech_ecommerce_address`.*, `xf_dbtech_ecommerce_country_Country_1`.*
            FROM `xf_dbtech_ecommerce_address`
            LEFT JOIN `xf_dbtech_ecommerce_country` AS `xf_dbtech_ecommerce_country_Country_1` ON (`xf_dbtech_ecommerce_country_Country_1`.`country_code` = `xf_dbtech_ecommerce_address`.`country_code`)
            WHERE (`xf_dbtech_ecommerce_address`.`user_id` = 1)
            ORDER BY `xf_dbtech_ecommerce_address`.`is_default` DESC, CONVERT (`xf_dbtech_ecommerce_address`.`title` USING utf8mb4) ASC
#0 src\XF\Db\Mysqli\Statement.php(196): XF\Db\AbstractStatement->getException('MySQL statement...', 1054, '42S22')
#1 src\XF\Db\Mysqli\Statement.php(39): XF\Db\Mysqli\Statement->getException('MySQL statement...', 1054, '42S22')
#2 src\XF\Db\Mysqli\Statement.php(54): XF\Db\Mysqli\Statement->prepare()
#3 src\XF\Db\AbstractAdapter.php(94): XF\Db\Mysqli\Statement->execute()
#4 src\XF\Mvc\Entity\Finder.php(1294): XF\Db\AbstractAdapter->query('
            SELECT `xf_...')
#5 src\addons\DBTech\eCommerce\Pub\Controller\Account.php(98): XF\Mvc\Entity\Finder->fetch()
#6 src\XF\Mvc\Dispatcher.php(350): DBTech\eCommerce\Pub\Controller\Account->actionAddressBook(Object(XF\Mvc\ParameterBag))
#7 src\XF\Mvc\Dispatcher.php(257): XF\Mvc\Dispatcher->dispatchClass('DBTech\\eCommerc...', 'AddressBook', Object(XF\Mvc\RouteMatch), Object(DBTech\eCommerce\Pub\Controller\Account), NULL)
#8 src\XF\Mvc\Dispatcher.php(113): XF\Mvc\Dispatcher->dispatchFromMatch(Object(XF\Mvc\RouteMatch), Object(DBTech\eCommerce\Pub\Controller\Account), NULL)
#9 src\XF\Mvc\Dispatcher.php(55): XF\Mvc\Dispatcher->dispatchLoop(Object(XF\Mvc\RouteMatch))
#10 src\XF\App.php(2184): XF\Mvc\Dispatcher->run()
#11 src\XF.php(391): XF\App->run()
#12 index.php(20): XF::runApp('XF\\Pub\\App')
#13 {main}
Request state
<pre class='xdebug-var-dump' dir='ltr'>
<small>C:\wamp64\www\xf\src\XF\Debugger.php:28:</small>
<b>array</b> <i>(size=4)</i>
  'url' <font color='#888a85'>=&gt;</font> <small>string</small> <font color='#cc0000'>'/xf/store/account/address-book'</font> <i>(length=33)</i>
  'referrer' <font color='#888a85'>=&gt;</font> <small>string</small> <font color='#cc0000'>'http://localhost/xf/store/'</font> <i>(length=29)</i>
  '_GET' <font color='#888a85'>=&gt;</font>
    <b>array</b> <i>(size=0)</i>
      <i><font color='#888a85'>empty</font></i>
  '_POST' <font color='#888a85'>=&gt;</font>
</pre>
I can't figure out where I did it wrong. Is this a bug or a configuration error? I need an urgent solution.
Thank you for your interest
Are you sure this didn’t happen just as you were upgrading? If this was a continuous issues, there would be more reports.
These problems occur when I try to enter these addresses.
index.php?store/checkout
index.php?store/account/address-book
I haven't seen a problem with other connections so far.
In addition, as a result of a lot of errors are as follows.
Maximum function nesting level of '256' reached, aborting!
I did a clean installation with DragonByte e-Commerce 1.5.3 and xenforo 2.1.5. The result has not changed.
I've run some sql commands via phpmyadmin to solve the problem myself, but again I failed.
This is a mistake and I hope you will help me with this.
I tried, but I didn't succeed.
SQL:
CREATE TABLE `xf_dbtech_ecommerce_address` (
  `address_id` int(10) UNSIGNED NOT NULL,
  `user_id` int(10) UNSIGNED NOT NULL,
  `address_state` enum('visible','verified','moderated','deleted') NOT NULL DEFAULT 'visible',
  `title` varchar(100) NOT NULL,
  `business_title` varchar(255) NOT NULL,
  `business_co` varchar(100) NOT NULL,
  `address1` varchar(100) NOT NULL,
  `address2` varchar(100) NOT NULL,
  `address3` varchar(100) NOT NULL,
  `address4` varchar(100) NOT NULL,
  `country_code` char(2) NOT NULL,
  `email` varchar(120) DEFAULT NULL,
  `sales_tax_id` varchar(100) NOT NULL,
  `order_count` int(10) UNSIGNED NOT NULL DEFAULT 0
) ENGINE=InnoDB DEFAULT CHARSET=utf8mb4;
You can resolve the error just now by running
SQL:
ALTER TABLE `xf_dbtech_ecommerce_address`
  ADD `is_default` TINYINT(1) UNSIGNED NOT NULL DEFAULT '0'
  AFTER `sales_tax_id`
I'll push a new version at some point this week that should resolve any half-applied upgrades.
Thank you for your attention. Your query worked. He's working now. ;)
However, it would be really good to fix this with an update. Because not everyone can run these queries.
Respects...
When I try to add an address, I get this error now.
Server error log
XF\Db\Exception: MySQL query error [1048]: Column 'address_id' cannot be null src/XF/Db/AbstractStatement.php:228
Stack trace
INSERT  INTO `xf_dbtech_ecommerce_address` (`user_id`, `title`, `business_title`, `business_co`, `address1`, `address2`, `address3`, `address4`, `country_code`, `sales_tax_id`, `is_default`, `address_id`, `address_state`, `order_count`) VALUES (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)
#0 src/XF/Db/Mysqli/Statement.php(196): XF\Db\AbstractStatement->getException('MySQL query err...', 1048, '23000')
#1 src/XF/Db/Mysqli/Statement.php(77): XF\Db\Mysqli\Statement->getException('MySQL query err...', 1048, '23000')
#2 src/XF/Db/AbstractAdapter.php(94): XF\Db\Mysqli\Statement->execute()
#3 src/XF/Db/AbstractAdapter.php(218): XF\Db\AbstractAdapter->query('INSERT  INTO `x...', Array)
#4 src/XF/Mvc/Entity/Entity.php(1452): XF\Db\AbstractAdapter->insert('xf_dbtech_ecomm...', Array, false)
#5 src/XF/Mvc/Entity/Entity.php(1184): XF\Mvc\Entity\Entity->_saveToSource()
#6 src/addons/DBTech/eCommerce/Service/Address/Create.php(145): XF\Mvc\Entity\Entity->save(true, false)
#7 src/XF/Service/ValidateAndSavableTrait.php(40): DBTech\eCommerce\Service\Address\Create->_save()
#8 src/addons/DBTech/eCommerce/Pub/Controller/Account.php(257): DBTech\eCommerce\Service\Address\Create->save()
#9 src/XF/Mvc/Dispatcher.php(350): DBTech\eCommerce\Pub\Controller\Account->actionAddressSave(Object(XF\Mvc\ParameterBag))
#10 src/XF/Mvc/Dispatcher.php(257): XF\Mvc\Dispatcher->dispatchClass('DBTech\\eCommerc...', 'AddressSave', Object(XF\Mvc\RouteMatch), Object(DBTech\eCommerce\Pub\Controller\Account), NULL)
#11 src/XF/Mvc/Dispatcher.php(113): XF\Mvc\Dispatcher->dispatchFromMatch(Object(XF\Mvc\RouteMatch), Object(DBTech\eCommerce\Pub\Controller\Account), NULL)
#12 src/XF/Mvc/Dispatcher.php(55): XF\Mvc\Dispatcher->dispatchLoop(Object(XF\Mvc\RouteMatch))
#13 src/XF/App.php(2184): XF\Mvc\Dispatcher->run()
#14 src/XF.php(391): XF\App->run()
#15 index.php(20): XF::runApp('XF\\Pub\\App')
#16 {main}
Request state
array(4) {
  ["url"] => string(35) "/store/account/address-book/save/0/"
  ["referrer"] => string(49) "http://******/store/account/address-book"
  ["_GET"] => array(0) {
  ["_POST"] => array(13) {
    ["title"] => string(4) "Work"
    ["business_title"] => string(6) "SametY"
    ["business_co"] => string(7) "XenForo"
    ["address1"] => string(24) "San.Sitesi.10 Blok No:13"
    ["address2"] => string(15) "Keşan / Edirne"
    ["address3"] => string(0) ""
    ["address4"] => string(0) ""
    ["country_code"] => string(2) "TR"
    ["sales_tax_id"] => string(0) ""
    ["_xfToken"] => string(8) "********"
    ["_xfRequestUri"] => string(27) "/store/account/address-book"
    ["_xfWithData"] => string(1) "1"
    ["_xfResponseType"] => string(4) "json"
Do you have a quick solution?
This is because the create table statement you created yourself is wrong. You're missing the primary key / auto increment on the address_id column.
Hello @SametY,
4.86 star(s) 7 ratings
