Hi
I pourchase the VbSlide Pro version.
I can´t run the differents Transition Effects to my slide.
All the parameters are default.
Only run the Default effect ( simple fade ). When I choise another transition effect ( for example scroll top ) , Simple fade remains there and "scroll top" never appears.
I instaled the pro version with brand free, and I uploaded all the pro files and I import the Pro product.
Can you Help me?
Best regards
Note: Is like I am runing lite version.
I was runing lite version, but I desinstalled it and delete all files. Them, I Re uploaded all the files and re installed xml product.
Can you Help me?
Best regards
