I've enabled the Pro option "Integrate Action Buttons", but there seems to be 2 issues with the styles:
1. Everything in the left side of the action buttons bar at the bottom of the post moves 3 pixels down. So it no longer lines up with the right side (Edit, Reply, etc.).
2. Even with this option selected, the cloud location still has leftover HTML in it. For example, if you put it below signature, there's an extra horizontal line at the bottom of the signature. I ended up commenting out the whole template so I don't have it any more, but I figured I should report it anyway.
Thanks.
Thanks.
