Bug Site Crashing
Blue6995
I have no idea why this has started to happen, unless it is something to do with my previous post in regard to Advanced Thanks/Like.
PHP Fatal error: Class 'FORUMTABS' not found in /home/rwfforum/public_html/vBulletin/dbtech/forumtabs/hooks/global_start.php on line 24
It seems the mod forumtabs causing the issue. and I have had to disable it to access my forum. Otherwise I get a message saying that The rwf-forum.co.uk page isn’t working
rwf-forum.co.uk is currently unable to handle this request.
Do I need to overwrite whichever file that is causing the problem or edit the global_start.php file?
It sounds like you are missing files, or the install didn't work as expected. Have you newly installed ForumTabs? Or have you had it installed for a while?
Make sure all the files from the latest versions are uploaded.
Also, what version of PHP are you using?
It has been installed for a while now.
PHP Version 5.4.45
Ok, I'll have a dig around to see what might be the issue. It might be something Fillip H. has some thoughts on too as you seem to be the only user reporting it at the moment. It may be a mod conflict in some way.
Update: I am unable to replicate any issues @ your site. I've re-enabled the product but it all appears to be working. Can you please provide step-by-step instructions for how to replicate this issue?
That is strange! Perhaps the fix of the other problem also solved this.
Many thanks for you help in fixing this
Hello Blue6995,
Legacy DragonByte Forum Tabs
