Hi. I want rename the folder admincp.
I know I have to change the config.php, but I have several plugins urged to dragonbyte and I wanted to know if I make changes to any of them. For example access the configuration panel to notify the plugin to change the name of the folder admincp.
These are the azap installed plugins:
Thank you sir
- DragonByte Tech: Advanced Post Thanks / Like (Lite
- DragonByte Tech: Re-Order Posts
- DragonByte Tech: SEO (Pro)
- DragonByte Tech: vB Optimise (Lite)
- DragonByte Tech: vBAnalytics (Lite)
- DragonByte Tech: vBCredits II Deluxe (Pro)
- DragonByte Tech: vBForms
Thank you sir
