XGC Paravain
I was not sure where to post this so just thought well you know lol
My question is well I want to get the vBActivity & Awards Pro and was wondering what the 3 month 1 year and lifetime is?
what is 3 months 3 months of what? and I notice this forum is for the (Lite) is there a forum for Pro?
The license length determines how long you will be able to access new updates (these include bug fixes and security fixes, though we usually also post manual file edit instructions for security fixes) :)
Ok was thinking after I posted lol ok my next question is I have the Lite installed would I have to reinstall the Pro?
You'd simply upload the new files and re-import the XML file, no uninstall is needed and all your existing data will be intact :)
Ok cool I just seen in the setting some thing about putting in a code for the brand free version thats why I thought i would ask :RpS_thumbup:
The branding free option should be in both the Lite and Pro versions, but it does require a separate purchase in order for it to work.
Ok I see so it has nothing to do with pro.
I have another question with my achievements are not calculating but I will make another thread for that
Thats cool I seen that now but I also found Copyright Managegement that's awesome because with all the Mods I uploaded my footer is becoming a mess so Yeah :RpS_thumbsup:
Yeah Copyright Management will condense them all to one line.
Yes thats done much better cleaner I noticed the host part of the copyright in the mods I noticed it was disabled but its in the footer is that some thing that needs to stay or did some how one of the mods get enabled?
If you are talking about the HiVelocity Hosting link, there is a option to disable that.
I have them all disabled but its still there, but I could not find that setting in the vBDonate is there not a setting in the vBDonate or am I looking in the wrong place?
Yes :cool: let me check
In the meantime I went to grab the vBActivity & Award Pro and I got a please wait [closed] message and then nothing, this when I clicked the "Add To Cart" tab
So does that mean the vBActivty Pro is unavailable?
or should the add to cart work? i'll try again just didn't know if the [closed] meant it was unavailable
also the Copyright Manager was off the is an option for making the copyright shorter tho
Legacy vBActivity & Awards
