I have the vbActivity and vbShout. One trend I am seing for these products is that to give permissions, I need to go into each Usergroup and apply permissions that way. Instead, can this be converted over to assign the permissions via the Setting Options area?
Personally, I like to set my Usergroup permissions when I first create a new usergroup and then I want to leave it alone unless something changes. I'd rather not have to go back into each usergroup every time I install a new product. I have a lot of usergroups. IMO, it would be much easier to go into a setting option for one of the products and then select all the usergroups I want to give certain permissions to. I like the fields on a lot of mods where you have to enter all the usergroup id's you want to give permissions to, but a more user friend way is where the admin has to highlight all the usergroups. A good example of this is in the EasyForm's mod.
Thanks for reading.
Thanks for reading.
