Bug Page not found - posts
xenigma
This suddenly appeared yesterday when clicking on links to posts (not threads):
Page not found
Disabling DBSEO fixes this. Changes since it last worked properly: I was moved to a new server yesterday.
You will need to make sure the .htaccess edits are still valid - maybe your new server doesn't read from .htaccess files?
Also, check the settings to make sure the database was ported correctly.
Not sure that I understand. The posts are physically there it's just that if I click on the post number at top right this results in a white page containing "Page not found". Similarly, if I click on a link inside someone's post where they have linked to a specific post somewhere else on the forum I also see "Page not found" when attempting to view that post. I have a widget on forum home showing new posts and clicking on these will also produce "page not found". Everything else seems fine, it's just the post links that don't work. Links from Google to my threads open correctly.
DBSEO redirect rules are in the /forum directory as before the move.
Can you please go to the DBSEO CP and check the rewrite rules for posts to make sure they are the same as the rewrite rules your old posts uses?
okay, which setting am I looking for?
"Thread go to post URL"?
My installation was a vbseo import so I assume that DBSEO just took the rules I had with VBSEO and that these are now visible in the "custom" fields beneath each list of possible url types. I can't remember what they were exactly when I used VBSEO. In any case, everything has worked perfectly with DBSEO until I was moved to a new server. Jus as a test, I selected a different setting in "Thread go to post URL" and that also resulted in "Page not found".
Yeah, that should be the setting for the permalinks like the ones here @ this site. Hmm...
Update: The problem was that the rewrite rules in /forum/.htaccess file had been altered. Fixing the last line from wiki_index.php to dbseo.php fixed the issue.
Ah, just noticed that vaultwiki now doesn't work. Clicking on my Wiki tab in the navbar and on internal Wiki links result in 404 page not found. Reverting your edit fixes that problem of course but that means that the other problem in post #6 above exists.
I have disabled my vaultwiki for now but it would be great if you could have another look into post #6. Your help is, as ever, greatly appreciated.
Have you tried applying the VaultWiki htaccess edits above the DBSEO htaccess entries?
I have never used VW so I cannot offer any further assistance unfortunately, the VW support team will be able to advise you further on this.
I was checking that earlier actually. Instead of dbseo.php or vbseo.php (as in the example below), vaultwiki requires wiki_index.php in that position. However, in that configuration, my wiki works but post links as described in post #6 don't work.
RewriteCond %{QUERY_STRING} !dbseourl=
RewriteCond %{REQUEST_URI} !(admincp/|dbseocp/|modcp/|cron|mobiquo|forumrunner|api\.php|reviewpost/|classifieds/|photopost/|wiki|yui)
RewriteRule ^(.*\.php)$ dbseo.php?dbseourl=$1 [L,QSA]
Moving the rules to the top of htaccess didn't result in any changes.
Then that's something you'll have to take up with the VW developers, unless they are able to highlight any specific issues or changes I can make to add compatibility, this is on them to provide a working set of rewrite rules.
Just a quick follow-up. The vaultwiki developer let me know that an environment variable expected by DBSEO was not being updated by VaultWiki when passing requests to dbseo.php. This issue has been fixed in the next version of vaultwiki.
Hello xenigma,
