Also causing issues on IE8.
I’ve disabled it for the time being.
EDIT: Couldn’t disable it atm. Messes up the post templates.
Also, for some reason the material in the postbit mod is clickable and if you click on any of the radio buttons, it will take you to the profile instead of changing to the correct tab.
2nd EDIT: Going to work with vbseo. Seems like that is most likely the issue. We’ll let you know what I find.
