You changed them the last time but there was no need, you're just enabling addon usegroups which are all subgroups of registered users. Nothing except registered users needs to be checked.
Well I can not seem to get it to work in IE, so for now I guess we will just have to live with it. I will keep messing around with it till David is able to jump on the mod and update it, that is once he finishes up with vBNotifs.
Don't work the select status in vb 4.1.4 with Google Chrome, FireFox, Internet Explorer and Opera!
I try to upload all files, but don't work... i try to import new xml but don't work...
Whyyyy?? T.T
ah... i try to clean the cache and cookie with ccleaner!
Another observation! is the first category that does not work! If that is put to use as sezonda category, and then below that it can also remain empty, because unused, then it works ... If not, does not work!
