Certainly,Are you using vBSEO? Can you please post the URL they're getting sent to before they are redirected?
http://www.forumURL.com/usertag.php?do=profilenotif&tab=quotes
http://www.forumURL.com/usertag.php?do=profilenotif&tab=mentions
http://www.forumURL.com/member.php?u=xxxx&tab=mentions#mentions
http://www.forumURL.com/member.php?u=xxxx&tab=quotes#quotes
In vbseo.php file I've changed this line:
array(VBSEO_USERID_URI, 'action', 'userid', 'username', 'tab', 'page', 'pp', 'vmid'),
to:
array(VBSEO_USERID_URI, 'action', 'userid', 'username', 'page', 'pp', 'vmid'),
Did so, edited vbseo.php file from:The URLs they are redirected to are legit, it's a bug in vBSEO, not this mod.
Here's what vBSEO support had to say about it that fixed it on our end:
Can I roll back? Am worried, I cannot disable vBSEO at this time.Can you try disabling vBSEO & its .htaccess edits and confirm that the redirects work then?
I cannot see what's causing all this. I followed your instructions, in vain!Rollbacks of our modifications are not supported, you may run into any number of unexpected problems that we'll be unable to assist with.
Why can't you disable vBSEO? You can temporarily close your forum if you're worried about members browsing it while you're testing.
