N Napo Customer Nov 15, 2012 #1 Hello! When I try to save the configuration of the forums, doesn't work. Boxes go blank again. Sorry for my english... Regards!
Fillip H. Staff member Owner Developer Customer Nov 15, 2012 #2 If you're running PHP 5.3.9 or newer, you need to set max_input_vars to 10000 in php.ini.
N Napo Customer Nov 15, 2012 #3 Thanks Fillip H.! Yes, I've running PHP 5.3.14, but I can't find this php.ini Where should I look?
Fillip H. Staff member Owner Developer Customer Nov 15, 2012 #4 Check the PHP Info in your AdminCP, it'll tell you what the loaded configuration file is.
N Napo Customer Nov 15, 2012 #5 Isn't there another way to solve it. Because we don't have access to the file... Thanks!
Ozzy47 Former Developer Customer Nov 16, 2012 #6 You would have to ask your host to increase the limit for you then.
Ozzy47 Former Developer Customer Nov 16, 2012 #8 Increasing the limit mainly just means that a user can eat up more memory by posting a lot of data, but there are other directives to control this as well, such as max post size and memory limit. I'd say the risk in increasing it is fairly minimal.
Fillip H. Staff member Owner Developer Customer Nov 16, 2012 #10 Then there's nothing we can do either, sorry
