billwill
Currently, I'm using vb3.8, ibproarcade and xperience. It seems adding vbshop to this mix would give me some of the functionality I want but don't currently have. I've been searching both here and vbulletin.org but still have a few questions about what your products can provide.
1. Is there a way for either me to reset everyone's points to zero and have it stick? I can delete them from xperience, but they just come right back.
2. Is there a way for me to set the points so they expire for each user one year (or six months, or some other period) from the earliest point was earned? For example Jane's points earned on July 31, 2010 are automatically deducted on July 31, 2011.
3. Is there a way for points to be deducted from user accounts each day they do not login?
4. Is there a way that a particular usergroup can add items to the store for so other users can use their points to purchase by other users?
5. If so, can it be set so they can't remove an item they've put up without admin help?
6. Is there a definitive answer to the question I posted earlier about your arcade being compatible with 3.8?
Thanks for your help in this.
bw
bw
