Hi. When editing or adding a file the Extentions Information box only shows the title of the table and not actual extentions. There are extentions loaded and the system works fine otherwise.
I don't have the default skin installed so unsure if it's a issue. If it is can I simply add or amend the template. It's only the css and I've not actually changed any files.
Any suggestions would be great thanks as I'll like to fix this issue before upgrading to Pro. I'm running out of download plugins as your seem to be the only once that's of any use at the moment!
