Legacy Disable by Style ID
Update: This will be implemented in the next version. The content will still be controlled and arranged from the Tabs/Views, but the templates will not be used so it will display correctly in the mobile style, provided the HTML used in the first place works in the mobile style.
Just installed the Pro version and wanted to play around with it a bit until I make it public. Just a couple users should test it together with me.
I have different styles and excluded all of them besides one.
What happens is indeed the TAB itself doesn't show up in the excluded but the "content" from the "views" shows up in every style
Any suggestions what I could do?
Thanks
This is working as intended. The setting controls what styles see the tab view (as you can see here @ DBTech) and what styles do not.
As this ticket is several months old, I'll close the thread :)
