Ok, had to DISABLE the Paid PRO version ....
We use a standard welcome thread on our site and have so for years. It's now reached 373 pages and something is happening with it that has never happened before, at least until we installed the PRO version of this mod ...
As an Admin, when I select this thread to read, my screen clears and I get a white screen of nothingness, with the word DONE on the execution line.
Upon checking further, it also doesn't work for anyone who is a moderator. In other words, it doesn't seem to be able to be read by any usergroup 5,6,7 and all they see is that blank white screen. The thread is perfectly readable by any other usergroup, including unregistered guests.
If I simply turn this PRO version of this mod OFF, everything is fine and all usergroups can read the thread. If I turn it back ON, the once again, usergroup 5,6,7 only see a blank white screen, when trying to read the thread. It's repeatable and consistent, so obviously the mod has a problem with long threads? (a guess), but I have no idea why it would impact just usergroups 5,6,7 ... bizarre ...
Regards,
Doug
Edit: Found the pattern. Any usergroup checked off in the PRO version as being able to use the mod, is unable to view long threads. If you uncheck their ability to use the mod, the thread is viewable again. I suspect it might be a memory problem for their mod with long threads, but I'm no programmer, just a customer.
Regards,
Doug
