Hi,
Cheers so far, really impressed with the mod! I am running VBSEO on the forum so think this may be part of the issue but if you have any suggestions on how fix I would be really grateful. Also I have the mod running on a devel version of the forum, I can PM you IP address if you want to see it.
I have cloud location set to "Below Posts", cloud style set to "No Header", and Disable Postbit Stats Collapse to "No". I do have VBSEO running on the forum and the URLs are output in this format:
http://domain.com/forumname/91946-post-title.html
If you go to a post and click the "Post Thanks/Like"selector the stats are shown correctly, click it again and the close. Now click thank or like, click the "Post Thanks/Like"selector again and you are taken to http://domain.com/forumname/-post.html#top and served a 404.
Many Thanks,
Tactics
Many Thanks,
Tactics
